usart receiving problem?
aravindpb5009
Hai
             i  am using LPC824 MCUXPRESSO  when i try to receive the char from the usart  by using usb to serial converter , i open the terminal in  my mcuxpresso ide and typed the char but that was unable to recive in my code , i used the example code which provided in mcuxpressso usart_polling example , i don't know what type of wrong i doing please let me know the solution
Thanks&Regards
Aravind p
Hello  Aravind palanisamy,
Please first confirm the UART pins you connect are the same with configuration in project.
And how about send character from board to PC?
If still can't work,  please take a screenshot about your  typed the char , I will test it on my side.
TIC
