tfm_psatest_ns on LPCpresso55s69.
已解决
跳至解决方案
1,999 次查看
ShinjiOhishi
Hello.
I tried tfm_psatest_ns on LPCpresso55s69.
From "TEST: 226" to "TEST: 231" and "TEST: 234" are the same function is called.
lpcxpresso55s69_tfm_psatest_ns/api-tests/val/test_entry_list.inc
I think they are incorrect code.
If these are bugs, please fix them.
Thanks.
标签 (1)
标记 (1)
1 解答
1,976 次查看
gusarambula
Hello ShinjiOhishi,
I edited my previous answer. I was confirmed that this is a typo and will be fixed on new releases of the SDK. Thank you for pointing this out!
Gustavo
在原帖中查看解决方案
3 回复数
1,983 次查看
gusarambula
Hello ShinjiOhishi,
Thank you for pointing this out.
It was confirmed that these are indeed typos. It was escalated to the SDK team know, and it will be fixed on future SDK releases.
My apologies for the inconvenience.
Gustavo
1,977 次查看
gusarambula
Hello ShinjiOhishi,
Gustavo
1,951 次查看
ShinjiOhishi
Hello Gustavo.
Thank you for fixing it.
