Hello everyone,
I'm trying to bring up the dev_msc_disk_bm_SDIO example on my customer hardware with two SDMMC devices (MCU is LPC55S69 with one SDMMC device connected to SD0 and one SDMMC device connected to SD1).
If I use SD0 (g_sd.hostPort = 0), the card initializes properly, it enumerates to a PC and the PC can read/write SD0.
If I try the same for SD1 (g_sd.hostPort = 1), SD1 does not initialize successfully. Instead the example code times out waiting for a kSD_Inserted event, even though there's a card in SD1.
Anyone have any insight into this issue?
DanL
