sd
sd
Nadia
Hello to all.
I am doing a writing project on a sd, I did others before and had no problem.
I'm using MCUXPRESSO 11.3.0, and SDK 2.8.2, my microcontroller is a LPC54616J, and I just create the project and I get #include "fsl_os_abstraction_free_rtos.h" error.
If anyone has had this happen I would appreciate your help.
Thank you very much.
Best regards.
ZhangJennie
HI Nadia
You use MCUXPRESSO 11.3.0, please use SDK2.9.0 with it.
https://mcuxpresso.nxp.com/en/select
If still have problem, let me know how to reproduce, I will test it directly on my side.
Jun Zhang
Nadia
Thanks for the quick response, but the error persists
ZhangJennie
Is this problem in demo code?
Please let us know how to reproduce your issue.
Jun Zhang
Nadia
ok.
My project worked, it only read a NMEA frame and got location data and saved them in variables, when I wanted to write them in a sd was the problem, when I added in Manage SDK component the sd part is when I get that failure, the same project before that had no failures, and when I added Middleware -> Memories -> SDMMC Stack the project failed.
ZhangJennie
I add SDMMC Stack from Middleware -> Memories -> SDMMC Stack to a hello_world SDK demo code. Build project. No error.
Please try the same.
Nadia
I load the example sdmmc_examples -> sdcard_polling and get failures
ZhangJennie
 I use  IDE 11.3+SDK2.9.0.
Attached is the steps I tested. No error.
Please follow attached video and test again.
Best Regards
Jun Zhang
