read image BMP from Sd card
Content originally posted in LPCWare by Saeed_Amareh on Mon May 09 00:05:11 MST 2016
Hello to all
I want Read image BMP from SD card with lpc1768 and show lcd7"
but my problem is decode image from sd .
can any one help me.
Thank you :)
bump
Content originally posted in LPCWare by Saeed_Amareh on Tue May 10 01:56:42 MST 2016
Thank you so much really great
Content originally posted in LPCWare by blasiis on Tue May 10 00:04:05 MST 2016
1) The basic structure for read sd sector  :
http://cache.nxp.com/documents/application_note/AN11070.zip?fpsp=1&WT_TYPE=Application%20Notes&WT_VE...
2) The bmp structure is in internet !
By
Stefano
Content originally posted in LPCWare by Saeed_Amareh on Mon May 09 23:42:54 MST 2016
my problem is :
1) Read the SD from SSP
2) Decode the bmp fomat.
Content originally posted in LPCWare by blasiis on Mon May 09 01:50:20 MST 2016
The problem are :
1) Read the SD from SSP o parallel ?
What is your difficulty ?
