problem with PRINTF()
Nadia
Good afternoon,
I'm using a LPC54616 and I have a problem, I put the instruction PRINTF, and I don't get anything out of the console, I have chosen the Newlibnano library (semihost) and I have taken the floating point, I don't know what happens.
If someone has had a similar problem and knows how to solve it, I'll thank them.
Greetings
gusarambula
Hello Nadia,
Would you please check your settings in accordance to  the following Knowledge Base document and let us know if it helped?
https://community.nxp.com/t5/MCUXpresso-IDE-Knowledge-Base/MCUXpresso-IDE-and-Semihosting/ta-p/11164...
Gustavo
Nadia
Hello, thank you very much for your quick answer, I have everything set up as a semihost, and I can't print anything on the surrounding console.
converse
Senior Contributor V
If you want to use semihosting, use standard C printf() and not the PRINTF macro.
Nadia
Hello, thank you very much for responding.
I'm using printf().
