probe-rs doesn't work with LPC55S69
chungae9ri
I am trying to use probe-rs.
When I run probe-rs list, I can see a jlink connection listed as below.
[0]: J-Link -- 1366:0105:000720762184 (J-Link)
But if I run below command to flash my rust binary,
probe-rs run --chip LPC55S69JBD100 --speed 1000 target/thumbv8m.main-none-eabihf/debug/lpc55s69
I got following error.
Finished `dev` profile [unoptimized + debuginfo] target(s) in 0.01s
Running `probe-rs run --chip LPC55S69JBD100 --speed 1000 target/thumbv8m.main-none-eabihf/debug/lpc55s69`
Error: Connecting to the chip was unsuccessful.
Caused by:
0: An ARM specific error occurred.
1: Error using access port FullyQualifiedApAddress { dp: Default, ap: V1(0) }.
2: Failed to read register DRW at address 0xd0c
3: An error occurred in the communication with an access port or debug port.
4: Target device responded with a FAULT response to the request.
But I can use my MCUxpression jlink debugger w/o any issues.
How can I use probe-rs with LPC55S69 EVK?
ErichStyger
Specialist I
I did use the LinkServer MCU-Link debug probes sucessfully with probe-rs.
https://mcuoneclipse.com/2024/03/17/nxp-mcu-link-for-rust-with-probe-rs/
https://mcuoneclipse.com/2025/10/15/getting-started-with-rust-on-nxp-lpc55s69-evk/
But I used it as CMSIS-DAP probe (not with the SEGGER firmware).
The SEGGER firmware is OEM and has restrictions of use, so probably this is the issue.
Can you try it with the default CMSIS-DAP firmware?
I hope this helps,
Erich
Harry_Zhang
Hi @chungae9ri
MCUXpresso IDE works normally with the same hardware.
This issue is likely due to SWD speed, the target not being held in reset, or another J-Link process still running.
The recommended steps are to close all J-Link servers, reduce the SWD speed.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eprobe-rs%20doesn't%20work%20with%20LPC55S69%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20use%20probe-rs.%3C%2FP%3E%3CP%3EWhen%20I%20run%20probe-rs%20list%2C%20I%20can%20see%20a%20jlink%20connection%20listed%20as%20below.%3C%2FP%3E%3CP%3E%5B0%5D%3A%20J-Link%20--%201366%3A0105%3A000720762184%20(J-Link)%3C%2FP%3E%3CP%3EBut%20if%20I%20run%20below%20command%20to%20flash%20my%20rust%20binary%2C%3C%2FP%3E%3CP%3Eprobe-rs%20run%20--chip%20LPC55S69JBD100%20--speed%201000%20target%2Fthumbv8m.main-none-eabihf%2Fdebug%2Flpc55s69%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20got%20following%20error.%3C%2FP%3E%3CP%3EFinished%20%60dev%60%20profile%20%5Bunoptimized%20%2B%20debuginfo%5D%20target(s)%20in%200.01s%3CBR%20%2F%3ERunning%20%60probe-rs%20run%20--chip%20LPC55S69JBD100%20--speed%201000%20target%2Fthumbv8m.main-none-eabihf%2Fdebug%2Flpc55s69%60%3CBR%20%2F%3EError%3A%20Connecting%20to%20the%20chip%20was%20unsuccessful.%3C%2FP%3E%3CP%3ECaused%20by%3A%3CBR%20%2F%3E0%3A%20An%20ARM%20specific%20error%20occurred.%3CBR%20%2F%3E1%3A%20Error%20using%20access%20port%20FullyQualifiedApAddress%20%7B%20dp%3A%20Default%2C%20ap%3A%20V1(0)%20%7D.%3CBR%20%2F%3E2%3A%20Failed%20to%20read%20register%20DRW%20at%20address%200xd0c%3CBR%20%2F%3E3%3A%20An%20error%20occurred%20in%20the%20communication%20with%20an%20access%20port%20or%20debug%20port.%3CBR%20%2F%3E4%3A%20Target%20device%20responded%20with%20a%20FAULT%20response%20to%20the%20request.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBut%20I%20can%20use%20my%20MCUxpression%20jlink%20debugger%20w%2Fo%20any%20issues.%3C%2FP%3E%3CP%3EHow%20can%20I%20use%20probe-rs%20with%20LPC55S69%20EVK%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20probe-rs%20doesn't%20work%20with%20LPC55S69%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259138%22%20target%3D%22_blank%22%3E%40chungae9ri%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VkpmXaOWmz%22%20data-para-id%3D%220%22%3E%20MCUXpresso%20IDE%20works%20normally%20with%20the%20same%20hardware.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22emL5Xrg1EB%22%20data-para-id%3D%220%22%3EThis%20issue%20is%20likely%20due%20to%20SWD%20speed%2C%20the%20target%20not%20being%20held%20in%20reset%2C%20or%20another%20J-Link%20process%20still%20running.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3EThe%20recommended%20steps%20are%20to%20close%20all%20J-Link%20servers%2C%20reduce%20the%20SWD%20speed.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3EHarry%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20probe-rs%20doesn't%20work%20with%20LPC55S69%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20did%20use%20the%20LinkServer%20MCU-Link%20debug%20probes%20sucessfully%20with%20probe-rs.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2024%2F03%2F17%2Fnxp-mcu-link-for-rust-with-probe-rs%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2024%2F03%2F17%2Fnxp-mcu-link-for-rust-with-probe-rs%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F15%2Fgetting-started-with-rust-on-nxp-lpc55s69-evk%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F15%2Fgetting-started-with-rust-on-nxp-lpc55s69-evk%2F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBut%20I%20used%20it%20as%20CMSIS-DAP%20probe%20(not%20with%20the%20SEGGER%20firmware).%3C%2FP%3E%3CP%3EThe%20SEGGER%20firmware%20is%20OEM%20and%20has%20restrictions%20of%20use%2C%20so%20probably%20this%20is%20the%20issue.%3C%2FP%3E%3CP%3ECan%20you%20try%20it%20with%20the%20default%20CMSIS-DAP%20firmware%3F%3C%2FP%3E%3CP%3EI%20hope%20this%20helps%2C%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E
