probe-rs doesn't work with LPC55S69
1,379件の閲覧回数
chungae9ri
I am trying to use probe-rs.
When I run probe-rs list, I can see a jlink connection listed as below.
[0]: J-Link -- 1366:0105:000720762184 (J-Link)
But if I run below command to flash my rust binary,
probe-rs run --chip LPC55S69JBD100 --speed 1000 target/thumbv8m.main-none-eabihf/debug/lpc55s69
I got following error.
Finished `dev` profile [unoptimized + debuginfo] target(s) in 0.01s
Running `probe-rs run --chip LPC55S69JBD100 --speed 1000 target/thumbv8m.main-none-eabihf/debug/lpc55s69`
Error: Connecting to the chip was unsuccessful.
Caused by:
0: An ARM specific error occurred.
1: Error using access port FullyQualifiedApAddress { dp: Default, ap: V1(0) }.
2: Failed to read register DRW at address 0xd0c
3: An error occurred in the communication with an access port or debug port.
4: Target device responded with a FAULT response to the request.
But I can use my MCUxpression jlink debugger w/o any issues.
How can I use probe-rs with LPC55S69 EVK?
1,173件の閲覧回数
ErichStyger
Specialist I
I did use the LinkServer MCU-Link debug probes sucessfully with probe-rs.
https://mcuoneclipse.com/2024/03/17/nxp-mcu-link-for-rust-with-probe-rs/
https://mcuoneclipse.com/2025/10/15/getting-started-with-rust-on-nxp-lpc55s69-evk/
But I used it as CMSIS-DAP probe (not with the SEGGER firmware).
The SEGGER firmware is OEM and has restrictions of use, so probably this is the issue.
Can you try it with the default CMSIS-DAP firmware?
I hope this helps,
Erich
1,249件の閲覧回数
Harry_Zhang
Hi @chungae9ri
MCUXpresso IDE works normally with the same hardware.
This issue is likely due to SWD speed, the target not being held in reset, or another J-Link process still running.
The recommended steps are to close all J-Link servers, reduce the SWD speed.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eprobe-rs%E3%81%AFLPC55S69%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3Eprobe-rs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eprobe-rs%20list%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20jlink%20%E6%8E%A5%E7%B6%9A%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B0%5D%3A%20J-Link%20--%201366%3A0105%3A000720762184%20(J-Link)%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6Rust%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3Eprobe-rs%20%E5%AE%9F%E8%A1%8C%20--chip%20LPC55S69JBD100%20--speed%201000%20target%2Fthumbv8m.main-none-eabihf%2Fdebug%2Flpc55s69%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%60dev%60%20%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%5B%E9%9D%9E%E6%9C%80%E9%81%A9%E5%8C%96%20%2B%20debuginfo%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%200.01%20%E7%A7%92%E3%81%A7%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%60probe-rs%20run%20--chip%20LPC55S69JBD100%20--speed%201000%20target%2Fthumbv8m.main-none-eabihf%2Fdebug%2Flpc55s69%60%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%81%E3%83%83%E3%83%97%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%8E%9F%E5%9B%A0%3A%3CBR%20%2F%3E%200%3A%20ARM%20%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E1%3A%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20%E3%83%9D%E3%83%BC%E3%83%88%20FullyQualifiedApAddress%20%7B%20dp%3A%20Default%2C%20ap%3A%20V1(0)%20%7D%20%E3%81%AE%E4%BD%BF%E7%94%A8%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%202%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200xd0c%20%E3%81%AE%20DRW%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E3%3A%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E4%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E8%A6%81%E6%B1%82%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20FAULT%20%E5%BF%9C%E7%AD%94%E3%81%A7%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81MCUxpression%20jlink%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELPC55S69%20EVK%20%E3%81%A7%20probe-rs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2299530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20probe-rs%20doesn't%20work%20with%20LPC55S69%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259138%22%20target%3D%22_blank%22%3E%40chungae9ri%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VkpmXaOWmz%22%20data-para-id%3D%220%22%3E%20MCUXpresso%20IDE%20%E3%81%AF%E5%90%8C%E3%81%98%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22emL5Xrg1EB%22%20data-para-id%3D%220%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81SWD%20%E9%80%9F%E5%BA%A6%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%A5%E3%81%AE%20J-Link%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E3%81%BE%E3%81%A0%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%22JTVCJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJWa3BtWGFPV216JTIyJTJDJTIycGFyYUlkeCUyMiUzQTAlMkMlMjJzcmMlMjIlM0ElMjIlMjBNQ1VYcHJlc3NvJTIwd29ya3MlMjBub3JtYWxseSUyMHdpdGglMjB0aGUlMjBzYW1lJTIwaGFyZHdhcmUuJTIyJTJDJTIyZHN0JTIyJTNBJTIyTUNVWHByZXNzbyVFNSU5QyVBOCVFNyU5QiVCOCVFNSU5MCU4QyVFNyU5QSU4NCVFNyVBMSVBQyVFNCVCQiVCNiVFNCVCOCU4QSVFNiVBRCVBMyVFNSVCOCVCOCVFNSVCNyVBNSVFNCVCRCU5QyVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyJTIwTUNVWHByZXNzbyUyMHdvcmtzJTIwbm9ybWFsbHklMjB3aXRoJTIwdGhlJTIwc2FtZSUyMGhhcmR3YXJlLiUyMiU3RCUyQyU3QiUyMmlkJTIyJTNBJTIyZW1MNVhyZzFFQiUyMiUyQyUyMnBhcmFJZHglMjIlM0EwJTJDJTIyc3JjJTIyJTNBJTIyJTIwVGhpcyUyMGlzc3VlJTIwaXMlMjBsaWtlbHklMjBkdWUlMjB0byUyMFNXRCUyMHNwZWVkJTJDJTIwdGhlJTIwdGFyZ2V0JTIwbm90JTIwYmVpbmclMjBoZWxkJTIwaW4lMjByZXNldCUyQyUyMG9yJTIwYW5vdGhlciUyMEotTGluayUyMHByb2Nlc3MlMjBzdGlsbCUyMHJ1bm5pbmcuJTIyJTJDJTIyZHN0JTIyJTNBJTIyJUU2JUFEJUE0JUU5JTk3JUFFJUU5JUEyJTk4JUU1JThGJUFGJUU4JTgzJUJEJUU2JTk4JUFGJUU3JTk0JUIxJUU0JUJBJThFU1dEJUU5JTgwJTlGJUU1JUJBJUE2JUUzJTgwJTgxJUU3JTlCJUFFJUU2JUEwJTg3JUU2JTlDJUFBJUU1JUE0JTg0JUU0JUJBJThFJUU5JTg3JThEJUU3JUJEJUFFJUU3JThBJUI2JUU2JTgwJTgxJUU2JTg4JTk2JUU1JThGJUE2JUU0JUI4JTgwJUU0JUI4JUFBSi1MaW5rJUU4JUJGJTlCJUU3JUE4JThCJUU0JUJCJThEJUU1JTlDJUE4JUU4JUJGJTkwJUU4JUExJThDJUUzJTgwJTgyJTIyJTJDJTIybWV0YWRhdGElMjIlM0ElMjIlMjIlMkMlMjJtYXRjaGVzJTIyJTNBbnVsbCUyQyUyMnRyYW5zbGF0ZWRCeSUyMiUzQW51bGwlMkMlMjJtZXRhRGF0YSUyMiUzQSU1QiU1RCUyQyUyMnRleHQlMjIlM0ElMjIlMjBUaGlzJTIwaXNzdWUlMjBpcyUyMGxpa2VseSUyMGR1ZSUyMHRvJTIwU1dEJTIwc3BlZWQlMkMlMjB0aGUlMjB0YXJnZXQlMjBub3QlMjBiZWluZyUyMGhlbGQlMjBpbiUyMHJlc2V0JTJDJTIwb3IlMjBhbm90aGVyJTIwSi1MaW5rJTIwcHJvY2VzcyUyMHN0aWxsJTIwcnVubmluZy4lMjIlN0QlMkMlN0IlMjJpZCUyMiUzQSUyMlZNMjQxeUs3anolMjIlMkMlMjJwYXJhSWR4JTIyJTNBMCUyQyUyMnNyYyUyMiUzQSUyMiUyMFRoZSUyMHJlY29tbWVuZGVkJTIwc3RlcHMlMjBhcmUlMjB0byUyMGNsb3NlJTIwYWxsJTIwSi1MaW5rJTIwc2VydmVycyUyQyUyMHJlZHVjZSUyMHRoZSUyMFNXRCUyMHNwZWVkJTJDJTIwYW5kJTIwdXNlJTIwLS1jb25uZWN0LXVuZGVyLXJlc2V0LiUyMiUyQyUyMmRzdCUyMiUzQSUyMiVFNSVCQiVCQSVFOCVBRSVBRSVFNyU5QSU4NCVFNiVBRCVBNSVFOSVBQSVBNCVFNiU5OCVBRiVFNSU4NSVCMyVFOSU5NyVBRCVFNiU4OSU4MCVFNiU5QyU4OUotTGluayVFNiU5QyU4RCVFNSU4QSVBMSVFNSU5OSVBOCVFRiVCQyU4QyVFOSU5OSU4RCVFNCVCRCU4RVNXRCVFOSU4MCU5RiVFNSVCQSVBNiVFRiVCQyU4QyVFNSVCOSVCNiVFNSU5QyVBOCVFOSU4NyU4RCVFNyVCRCVBRSVFNCVCOCU4QiVFNCVCRCVCRiVFNyU5NCVBOC0tY29ubmVjdCVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyJTIwVGhlJTIwcmVjb21tZW5kZWQlMjBzdGVwcyUyMGFyZSUyMHRvJTIwY2xvc2UlMjBhbGwlMjBKLUxpbmslMjBzZXJ2ZXJzJTJDJTIwcmVkdWNlJTIwdGhlJTIwU1dEJTIwc3BlZWQlMkMlMjBhbmQlMjB1c2UlMjAtLWNvbm5lY3QtdW5kZXItcmVzZXQuJTIyJTdEJTJDJTdCJTIyaWQlMjIlM0ElMjJlS0o0V3lZTWxCJTIyJTJDJTIycGFyYUlkeCUyMiUzQTAlMkMlMjJzcmMlMjIlM0ElMjIlMjBTd2l0Y2hpbmclMjB0aGUlMjBvbi1ib2FyZCUyMGRlYnVnZ2VyJTIwdG8lMjBDTVNJUy1EQVAlMjAoREFQTGluayklMjBtYXklMjBhbHNvJTIwaGVscCUyQyUyMGFzJTIwaXQlMjBpcyUyMGdlbmVyYWxseSUyMG1vcmUlMjBzdGFibGUlMjB3aXRoJTIwcHJvYmUtcnMuJTIyJTJDJTIyZHN0JTIyJTNBJTIyJUU1JUIwJTg2JUU2JTlEJUJGJUU4JUJEJUJEJUU4JUIwJTgzJUU4JUFGJTk1JUU1JTk5JUE4JUU1JTg4JTg3JUU2JThEJUEyJUU1JTg4JUIwQ01JUy1EQVAlRUYlQkMlODhEQVBMaW5rJUVGJUJDJTg5JUU0JUI5JTlGJUU1JThGJUFGJUU4JTgzJUJEJUU2JTlDJTg5JUU2JTg5JTgwJUU1JUI4JUFFJUU1JThBJUE5JUVGJUJDJThDJUU1JTlCJUEwJUU0JUI4JUJBJUU1JUFFJTgzJUU5JTgwJTlBJUU1JUI4JUI4JUU1JUFGJUI5cHJvYmUtcnMlRTYlOUIlQjQlRTclQTglQjMlRTUlQUUlOUElRTMlODAlODIlMjIlMkMlMjJtZXRhZGF0YSUyMiUzQSUyMiUyMiUyQyUyMm1hdGNoZXMlMjIlM0FudWxsJTJDJTIydHJhbnNsYXRlZEJ5JTIyJTNBbnVsbCUyQyUyMm1ldGFEYXRhJTIyJTNBJTVCJTVEJTJDJTIydGV4dCUyMiUzQSUyMiUyMCUyMiU3RCU1RCU3RCU1RA%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20J-Link%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E9%96%89%E3%81%98%E3%80%81SWD%20%E9%80%9F%E5%BA%A6%E3%82%92%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-node%3D%22text%22%20data-slate-fragment%3D%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%3D%3D%22%3E%3CSPAN%20class%3D%22hover-sent%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22VM241yK7jz%22%20data-para-id%3D%220%22%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20probe-rs%20doesn't%20work%20with%20LPC55S69%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81probe-rs%20%E3%81%A7%20LinkServer%20MCU-Link%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2024%2F03%2F17%2Fnxp-mcu-link-for-rust-with-probe-rs%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2024%2F03%2F17%2Fnxp-mcu-link-for-rust-with-probe-rs%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F15%2Fgetting-started-with-rust-on-nxp-lpc55s69-evk%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2025%2F10%2F15%2Fgetting-started-with-rust-on-nxp-lpc55s69-evk%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%20CMSIS-DAP%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(SEGGER%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3CP%3ESEGGER%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%20OEM%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E4%BD%BF%E7%94%A8%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20CMSIS-DAP%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%3C%2FP%3E%3C%2FLINGO-BODY%3E
