please help lpc2144
please help lpc2144
Esam
It has been replaced with a new piece, but unfortunately it does not work. I have a second piece that works well. How can I copy the information on the new piece?
Esam
Hello LPC 2144 FBD64 ,LPC2144FBD64 -151
what is the difference
Pavel_Hernandez
Hello, there is only one version, I suggest reviewing the next information on the page.
LPC2144FBD64 Product Information|NXP
Pavel
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I review your information, but this does not have enough details, if you are looking to flash your MCU I recommend using a debugger, like the MCU Link.
MCU Link JTAG/SWD Debug Probe | NXP Semiconductors
Pavel
Esam
  • I want an explanation about the possibility of copying programming from a well-functioning piece to a new piece, with thanks
Pavel_Hernandez
Hello, I understand maybe you could try with BLHOST read memory command.
MCUBLHOSTUG.pdf (nxp.com)
Pavel
Esam
What is the name of the programmer and its program and how to connect it to the computer
Pavel_Hernandez
Hello, if you have a custom board, you may need an external debugger and put the LPC in ISP mode.
Pavel
Esam
Please explain how to handle and copy a new piece
Pavel_Hernandez
Hello, when you have the MCU connected to the PC, you may need to install the spsdk or blhost.
Then you can read the memory.
Pavel
