pcf8563 register value is different with a data sheet
hyeongjinkim
PCF8563
Now we just check and compare with a PCF8563 data sheet and real register value.
but our real 01h value and a data sheet value is different
our register value
01h - 0x80 , 0xC0
on data sheet
01h - N (0x00)
we compare with a  TABLE 4. Formatted registers overview
can you check that problem please?
guoweisun
can you catch the waveform using oscilloscope to show each bit value for your read command?
hyeongjinkim
Thank you for replying
other reset register value is same all right but 01h reset register value is different with a data sheet
Table 27. Register reset value[1]
01h Control_status_2              0  0  0  0  0  0  0  0
guoweisun
Do you mean different lots have different default value of 0X01 register?
hyeongjinkim
thank you for replying
reset value 01h real value and 01h data sheet value is different does it make any problem? or error?
PCF8563 Reset value​
   00h01h 02h  03h04h  05h06h07h08h
 LOTXD842  0x080x000x800x000x00 0x010x000x010x00
 XD920 0x080x000x800x000x00 0x010x000x010x00
 XD915 0x080x800x900xF40xA2 0xAD0x940x1C0x85
 nG936 0x080xC00xD70xBF0xEC 0xFA0xD30x590xB9
 nG038 0x080xC00xE80x830xF8 0xC70xEF0x760x71
guoweisun
what is about the result after your read others registers?
Only this 0X01 has read error?
hyeongjinkim
other reset register value is same as data sheet ,but 01h reset register value is different with a data sheet
guoweisun
hyeongjinkim
thank you for your replying
i will check that value and waveform , if chips make problem again i will posting again thank you
