maximum output timer lpc4337
1,364 次查看
diegotorres
hi I'm working on lpc4337 and I'm trying generate an output with a timer as 10mhz frequency and I just can get approximately 300khz. That's possible?get an output higher as 10mhz??regards
标记 (1)
1,225 次查看
soledad
Which timer are you using?
Please check the AN11538 application note, this application note is a collection of examples and usage notes for the
SCTimer/PWM block used in NXP microcontrollers.
http://www.nxp.com/documents/application_note/AN11538.zip
I hope this helps,
Sol
