lwip running on ucosiii based on lpc4357 platform
lpcware
Content originally posted in LPCWare by nirvana_xun on Mon Oct 28 18:09:56 MST 2013
i just ported the ucosiii and lwip on the lpc4357 target board. for testing, i used the freertos lwip echo to this environment, after a few configuration and setting,, the program is running on my board, but the porting seems to not work, i cand just get the ip, when i start the echo thread, the whole program seems running to a dead end. i doubt whether there are some problems with lwip porting, the os emulation file is add below.anyone got some idea?thanks
Original Attachment has been moved to: sys_arch.h.zip
Original Attachment has been moved to: sys_arch_ucosiii.c.zip
Original Attachment has been moved to: lpc18xx_43xx_emac.c.zip
