lpcxpresso55s16_freertos_spi example can not find in SDK v2.14.0
1,989 次查看
felix1
I can find a freertos SPI example in LPC55S16 SDK v2.13.0, but I can not find it in SDK v2.14.0. The freertos SPI example is indeed remove from SDK v2.14.0 or I miss something in SDK builder?
1,961 次查看
xiangjun_rong
Yes, the version 2.14.0 of SDK package for LPC55S16 has removed the freertos_spi,freertos_usart, and freertos_i2c examples, I have downloaded the package, I copy the directory.
XiangJun Rong
5 回复数
1,980 次查看
xiangjun_rong
Can you tell us the lpcxpresso55s16_freertos_spi example directory in the old version LPC55S16 SDK v2.13.0?
XiangJun Rong
1,975 次查看
felix1
The directory is \SDK_2_13_0_LPCXpresso55S16\boards\lpcxpresso55s16\rtos_examples\freertos_spi
1,962 次查看
xiangjun_rong
XiangJun Rong
1,921 次查看
felix1
Why NXP removed the freertos_spi example from SDK v2.14.0?
Because I use freertos_spi example as my project's code base, I need to know if there is any bug in this example.
1,886 次查看
xiangjun_rong
You can use the old version of lpcxpresso55s16_freertos_spi example, there is not bug for the example.
XiangJun Rong
