lpc55s28 adc0_12 not working
6,077 次查看
PatrickLai
I'm configuring ADC0_3 and ADC0_12 for LPC55S28. ADC0_3 can get different values for different input voltages, but ADC0_12 always gets 4092~4095 for any input voltages. Please help to check what is the possible cause of this issue. Attached my current changes for ADC
Patrick
3,314 次查看
Hello @PatrickLai
I'm sorry for the late reply. I’m not sure why our internal system didn’t send me a notification when you updated this thread.
Anyway, I have tested your project and checked the issue. The problem is that ADC0_12 corresponds to channel (ADCH) 4, not 12. So please change
#define DEMO_LPADC_USER_CHANNEL 12U
to
#define DEMO_LPADC_USER_CHANNEL 4U.
Also, please configure the sample channel mode to "Single-ended mode, as only the B-side channel is converted" . As shown below.
After these changes, it works correctly.
Hope it helps.
Thank you.
Alice
11 回复数
6,052 次查看
Hello @PatrickLai
Please check your hardware to verify whether ADC0_12 is connected to a high voltage on the board. Also, please confirm that you are connected to the correct pin.
Thank you.
Alice
5,995 次查看
PatrickLai
Hi Alice,
I've tested the input voltage of ADC0_12 pin on the MCU is 1.9V, so the hardware should be ok. but the adc value is still in range of 4091 and 4095
5,981 次查看
Hello @PatrickLai
Please connect GND for testing.
If the issue persists, use the configuration tool to set up the ADC and this channel.
Alice
3,997 次查看
PatrickLai
Hi Alice,
I connected to ground and the adc value is still not right. I have trouble using config tool to setup adc. So I used the sample code lpadc_polling from the SDK. I only change the ADC channel to ADC0_12 and it still doesn't work. The ADC0_3 is ok. Could you please help to check based on the sample code and my configuration?
3,818 次查看
Hello @PatrickLai
Do you use the LPCXpresso55S28-EVK board? If yes, please check the schematic; this pin is connected to VDD.
Alice
3,815 次查看
PatrickLai
Hi Alice,
I tested on the evk, and tried removing the R75 and press the USER button(SW3), adc value is still the same, around 4094~4095. Please help to check again.
Patrick
3,812 次查看
Hello @PatrickLai
Please share your complete project.
Alice
3,809 次查看
PatrickLai
Hi Alice,
project code uploaded.
Patrick
3,682 次查看
PatrickLai
Hi @Alice_Yang ,
Any udpate?
Patrick
3,315 次查看
Hello @PatrickLai
to
Hope it helps.
Thank you.
Alice
3,230 次查看
PatrickLai
Hi Alice,
It works now. Thank you for your help.
Patrick
%3CLINGO-SUB%20id%3D%22lingo-sub-2268403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S28%20ADC0_12%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%BA%20LPC55S28%20%E9%85%8D%E7%BD%AE%20ADC0_3%20%E5%92%8C%20ADC0_12%E3%80%82ADC0_3%20%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E8%BE%93%E5%85%A5%E7%94%B5%E5%8E%8B%E4%B8%8B%E4%BC%9A%E5%BE%97%E5%88%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC%EF%BC%8C%E4%BD%86%20ADC0_12%20%E5%9C%A8%E4%BB%BB%E4%BD%95%E8%BE%93%E5%85%A5%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%83%BD%E4%BC%9A%E5%BE%97%E5%88%B0%204092~4095%20%E7%9A%84%E5%80%BC%E3%80%82%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%A3%80%E6%9F%A5%E5%AF%BC%E8%87%B4%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E5%8F%AF%E8%83%BD%E5%8E%9F%E5%9B%A0%E3%80%82%E9%99%84%E4%B8%8A%E6%88%91%E7%9B%AE%E5%89%8D%E5%AF%B9%20ADC%20%E6%89%80%E5%81%9A%E7%9A%84%E6%9B%B4%E6%94%B9%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%B8%95%E7%89%B9%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252433%22%20target%3D%22_blank%22%3E%40PatrickLai%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%E4%BB%A5%E9%AA%8C%E8%AF%81%20ADC0_12%20%E6%98%AF%E5%90%A6%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E4%B8%8A%E7%9A%84%E9%AB%98%E7%94%B5%E5%8E%8B%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%E6%82%A8%E8%BF%9E%E6%8E%A5%E7%9A%84%E9%92%88%E8%84%9A%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CAlice%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E8%BF%87%E5%8D%95%E7%89%87%E6%9C%BA%20ADC0_12%20%E5%BC%95%E8%84%9A%E7%9A%84%E8%BE%93%E5%85%A5%E7%94%B5%E5%8E%8B%E4%B8%BA%201.9V%EF%BC%8C%E6%89%80%E4%BB%A5%E7%A1%AC%E4%BB%B6%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E4%BD%86%20adc%20%E5%80%BC%E4%BB%8D%E5%9C%A8%204091%20%E5%92%8C%204095%20%E4%B9%8B%E9%97%B4%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252433%22%20target%3D%22_blank%22%3E%40PatrickLai%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%E6%B5%8B%E8%AF%95%E6%97%B6%E8%AF%B7%E8%BF%9E%E6%8E%A5%20GND%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E5%A6%82%E6%9E%9C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E8%AE%BE%E7%BD%AE%20ADC%20%E5%92%8C%E6%AD%A4%E9%80%9A%E9%81%93%E3%80%82%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%88%B1%E4%B8%BD%E4%B8%9D%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%9E%E6%8E%A5%E4%BA%86%E5%9C%B0%E7%BA%BF%EF%BC%8C%E4%BD%86%20adc%20%E5%80%BC%E4%BB%8D%E7%84%B6%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E8%AE%BE%E7%BD%AE%20adc%20%E6%97%B6%E9%81%87%E5%88%B0%E5%9B%B0%E9%9A%BE%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20SDK%20%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%20lpadc_polling%E3%80%82%E6%88%91%E5%8F%AA%E5%B0%86%20ADC%20%E9%80%9A%E9%81%93%E6%94%B9%E4%B8%BA%20ADC0_12%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82ADC0_3%20%E6%AD%A3%E5%B8%B8%E3%80%82%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%A0%B9%E6%8D%AE%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%92%8C%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E5%B8%AE%E5%8A%A9%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3CBR%20%2F%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%B6%88%E6%81%AF%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EPatrick%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252433%22%20target%3D%22_blank%22%3E%40PatrickLai%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E5%BD%93%E4%BD%A0%E6%9B%B4%E6%96%B0%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%86%85%E9%83%A8%E7%B3%BB%E7%BB%9F%E6%B2%A1%E6%9C%89%E5%90%91%E6%88%91%E5%8F%91%E9%80%81%E9%80%9A%E7%9F%A5%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E4%BA%86%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E6%A3%80%E6%9F%A5%E4%BA%86%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8E%20ADC0_12%20%E5%AF%B9%E5%BA%94%E7%9A%84%E6%98%AF%E9%80%9A%E9%81%93%20(ADCH)%204%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%2012%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AF%B7%E5%B0%86%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20DEMO_LPADC_USER_CHANNEL%2012U%3C%2FCODE%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%E6%94%B9%E4%B8%BA%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20DEMO_LPADC_USER_CHANNEL%204U%3C%2FCODE%3E.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E5%B0%86%E9%87%87%E6%A0%B7%E9%80%9A%E9%81%93%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E4%B8%BA%22%E5%8D%95%E7%AB%AF%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%8F%AA%E6%9C%89%20B%20%E7%AB%AF%E9%80%9A%E9%81%93%E4%BC%9A%E8%BD%AC%E6%8D%A2%E4%B8%BA%22%20%E3%80%82%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%E3%80%82%20%3C%2FFONT%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1768373641678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1768373641678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1768373641678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372761i07EE9035DE62334B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1768373641678.png%22%20alt%3D%22Alice_Yang_0-1768373641678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%224%22%3E%E7%BB%8F%E8%BF%87%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%94%B9%E5%90%8E%EF%BC%8C%E5%AE%83%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_1-1768373677726.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_1-1768373677726.png%22%20style%3D%22width%3A%20148px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_1-1768373677726.png%22%20style%3D%22width%3A%20148px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372763i49A49526F646BA47%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_1-1768373677726.png%22%20alt%3D%22Alice_Yang_1-1768373677726.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc55s28%20adc0_12%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%88%B1%E4%B8%BD%E4%B8%9D%E3%80%81%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%B8%95%E7%89%B9%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
