lpc5528 set to slave i2s role
1,809件の閲覧回数
harry3
Hi nxp team,
I now need to set the I2S peripheral of the LPC5528 to slave mode. The I2S master role is provided by another MCU device. I have checked the LPC5528 example routines and found no method for setting I2S to slave mode. Could you please tell me how to configure the LPC5528 as an I2S slave?
thanks
harry
ラベル(2)
6 返答(返信)
1,791件の閲覧回数
Harry_Zhang
Hi @harry3
You can refer to the SDK evkmimxrt685_i2s_interrupt_transfer demo.
It includes the i2s master and i2s master slave.
Harry
1,784件の閲覧回数
harry3
hi zhang, After the i2s is set as the slave, all clock signals come from the external MCU. How should the mclk, bclk, and wsclk of i2s be configured? The clock in the example you provided comes from the 5528 itself, which is different from my schematic design. i2s做slave之后,时钟信号都是来自于外部的MCU。 i2s的mclk,bclk,wsclk要怎么配置呢? 你举的这个例程的时钟是来自于5528自身,和我的图示设计是不同的。 thanks harry
1,665件の閲覧回数
Harry_Zhang
Hi @harry3
Based on your need.
For the master(RT685), you can refer to the evkmimxrt685_i2s_interrupt_transfer_cm33 demo.
RT685 clock configuration can be maintained in demo mode.
RT685 (Master)  generate and output all three clocks: MCLK, BCLK (SCK), and WS (LRCLK).
For the slave(lpc55s28), you can refer to the lpcxpresso55s28_i2s_interrupt_transfer demo.
LPC55S28 (Slave)  receive these three clocks. Only MCLK needs explicit SYSCON configuration.
    /* Attach PLL clock to MCLK for I2S, no divider */
    CLOCK_AttachClk(kPLL0_to_MCLK);
    SYSCON->MCLKDIV = SYSCON_MCLKDIV_DIV(0U);
    SYSCON->MCLKIO  = 1U;
    CLOCK_SetClkDiv(kCLOCK_DivPll0Clk, 0U, true);
    CLOCK_SetClkDiv(kCLOCK_DivPll0Clk, 1U, false);
    /*!< Switch PLL0 clock source selector to XTAL16M */
    /* I2S clocks */
    CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM6);
    CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM7);
need modify  to
    SYSCON->MCLKIO  = 0U;
BCLK and WS do not require direction settings on LPC55S28; once the Flexcomm I2S is configured as Slave.
I think you can try it.
Harry Zhang
1,658件の閲覧回数
harry3
你好Harry,
   非常感谢你的支持。
    先不讨论做主还是做从的问题,我请教一个关于channel的问题,在sdk例程中的有关DMA i2s的例程都是默认FC7做I2S TX,FC6做i2s RX,并且FC7共享时钟给FC6。对应的channel是tx对应19和rx对应16。它们之间的对应关系是怎么得到的呢?我试过把DEMO_I2S_TX_CHANNEL改成18,或导致EVK无法输出。说明它们之间的这个值是有对应逻辑关系的。这个关系在哪里可以找到?
thansk
harry
1,779件の閲覧回数
Harry_Zhang
Hi @harry3
两个 MCU 之间的 I2S 直连,通常只需要 BCLK+ LRCLK+ SD(数据) 三根线,不需要 MCLK。Master产生 BCLK/WS,Slave按该时钟采样/发送数据。I2S 最初定义的就是“三线总线”,MCLK 并不是数据传输必须的信号。
MCLK 多见于 CODEC/ADC/DAC 等音频器件作为其内部过采样与数字滤波的参考时钟,对 MCU↔MCU 的 I2S 链路并非硬性要求。
如果你的RT685是master,BCLK+ LRCLK是由RT685产生。LPC55S28不需要产生BCLK+ LRCLK。
   /* Set flexcomm3 SCK, WS from shared signal set 0 */
    I2S_BRIDGE_SetFlexcommSignalShareSet(kI2S_BRIDGE_Flexcomm3, kI2S_BRIDGE_SignalSCK, kI2S_BRIDGE_ShareSet0);
    I2S_BRIDGE_SetFlexcommSignalShareSet(kI2S_BRIDGE_Flexcomm3, kI2S_BRIDGE_SignalWS, kI2S_BRIDGE_ShareSet0);
Harry
1,775件の閲覧回数
harry3
hi harry 张,
谢谢你的支持
例程中用到I2S的共享,我看到的一般是有先设定源时钟到share0,在把share0 分配到电路对应的flexcomm组。例如下面这样
我做slave,是不是不需要按照上面方法配置SCLK和WS clk. 直接用两句SYSCTL_SetShareSet(...);就可以了?
第二个问题,关于时钟,是不是在slave模式下不需要下图配置i2s的时钟部分。
thanks
harry
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2336244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Elpc5528%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96I2S%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81LPC5528%E3%81%AEI2S%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82I2S%E3%83%9E%E3%82%B9%E3%82%BF%E3%81%AE%E5%BD%B9%E5%89%B2%E3%81%AF%E3%80%81%E5%88%A5%E3%81%AEMCU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82LPC5528%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81I2S%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82LPC5528%E3%82%92I2S%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379883i79DEF09AB16D5E73%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-18%20205458.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2336244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%94%A8%E6%88%B7%E8%AE%BA%E5%9D%9B%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336389%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336389%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%81%E3%83%A3%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EI2S%E5%85%B1%E6%9C%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%ABshare0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E6%AC%A1%E3%81%ABshare0%E3%81%8C%E5%9B%9E%E8%B7%AF%E3%81%AE%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8Bflexcomm%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%82%92%E7%9B%AE%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379930i39F8313ACCD1AA8A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20153923.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABSCLK%E3%81%A8WS%20clk%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CSPAN%3ESYSCTL_SetShareSet(...)%3B%20%E3%82%92%202%20%E8%A1%8C%E3%81%A0%E3%81%91%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2%E3%81%A4%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%ABI2S%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379929iE4EB78B3A86BA306%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-20%20152916.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336364%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336364%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259484%22%20target%3D%22_blank%22%3E%40harry3%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E2%E3%81%A4%E3%81%AEMCU%E9%96%93%E3%81%AEI2S%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81BCLK%E3%80%81LRCLK%E3%80%81SD%EF%BC%88%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%89%E3%81%AE3%E6%9C%AC%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%81%AE%E3%81%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82MCLK%E3%81%AF%E4%B8%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AFBCLK%2FWS%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%E3%81%93%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%2F%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82I2S%E3%81%AF%E5%85%83%E3%80%85%E3%80%8C3%E7%B7%9A%E5%BC%8F%E3%83%90%E3%82%B9%E3%80%8D%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81MCLK%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E4%BC%9D%E9%80%81%E3%81%AB%E5%BF%85%E9%A0%88%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EMCLK%E3%81%AF%E3%80%81CODEC%2FADC%2FDAC%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E6%A9%9F%E5%99%A8%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E5%86%85%E9%83%A8%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%84%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%9F%BA%E6%BA%96%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81MCU%E9%96%93%E3%81%AEI2S%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E5%BF%85%E9%A0%88%E8%A6%81%E4%BB%B6%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3ERT685%E3%81%8C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81BCLK%2BLRCLK%E3%81%AFRT685%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82LPC55S28%E3%81%AFBCLK%2BLRCLK%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%2F*%20Set%20flexcomm3%20SCK%2C%20WS%20from%20shared%20signal%20set%200%20*%2F%0A%20%20%20%20I2S_BRIDGE_SetFlexcommSignalShareSet(kI2S_BRIDGE_Flexcomm3%2C%20kI2S_BRIDGE_SignalSCK%2C%20kI2S_BRIDGE_ShareSet0)%3B%0A%20%20%20%20I2S_BRIDGE_SetFlexcommSignalShareSet(kI2S_BRIDGE_Flexcomm3%2C%20kI2S_BRIDGE_SignalWS%2C%20kI2S_BRIDGE_ShareSet0)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81zhang%E3%81%95%E3%82%93%E3%80%82i2s%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%AF%E5%A4%96%E9%83%A8MCU%E3%81%8B%E3%82%89%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82i2s%E3%81%AEmclk%E3%80%81bclk%E3%80%81wsclk%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E7%A4%BA%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF5528%E8%87%AA%E4%BD%93%E3%81%8B%E3%82%89%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82i2s%20%E3%81%8C%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%A4%96%E9%83%A8%20MCU%20%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%20i2s%20%E3%81%AE%20mclk%E3%80%81bclk%E3%80%81wsclk%20%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259484%22%20target%3D%22_blank%22%3E%40harry3%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ESDK%E3%81%AEevkmimxrt685_i2s_interrupt_transfer%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81I2S%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8I2S%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2026-03-20_12-08-59.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-20_12-08-59.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-20_12-08-59.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-20_12-08-59.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379904iBA401D05481172B4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2026-03-20_12-08-59.png%22%20alt%3D%22Snipaste_2026-03-20_12-08-59.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338082%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338082%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%95%E3%81%A6%E3%81%8A%E3%81%8D%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82DMA%20I2S%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%20SDK%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81FC7%20%E3%81%AF%E5%B8%B8%E3%81%AB%20I2S%20TX%20(%E9%80%81%E4%BF%A1)%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81FC6%20%E3%81%AF%20I2S%20RX%20(%E5%8F%97%E4%BF%A1)%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81FC7%20%E3%81%AF%20FC6%20%E3%81%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%20TX%2019%20%E3%81%A8%20RX%2016%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%AF%BE%E5%BF%9C%E9%96%A2%E4%BF%82%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82DEMO_I2S_TX_CHANNEL%3CSPAN%3E%E3%82%92%2018%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81EVK%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%81%AE%E9%96%93%E3%81%AB%E8%AB%96%E7%90%86%E7%9A%84%E3%81%AA%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%A2%E4%BF%82%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-24%20115229.png%22%20style%3D%22width%3A%20610px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-24%20115229.png%22%20style%3D%22width%3A%20610px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-24%20115229.png%22%20style%3D%22width%3A%20610px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380140i80EA8AC81803F162%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-24%20115229.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-03-24%20115229.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpc5528%20set%20to%20slave%20i2s%20role%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259484%22%20target%3D%22_blank%22%3E%40harry3%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%83%8B%E3%83%BC%E3%82%BA%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%EF%BC%88RT685%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81evkmimxrt685_i2s_interrupt_transfer_cm33%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3ERT685%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%83%87%E3%83%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%82%E7%B6%AD%E6%8C%81%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ERT685%EF%BC%88%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%EF%BC%89%E3%81%AF%E3%80%81MCLK%E3%80%81BCLK%EF%BC%88SCK%EF%BC%89%E3%80%81WS%EF%BC%88LRCLK%EF%BC%89%E3%81%AE3%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E7%94%9F%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E5%81%B4%EF%BC%88lpc55s28%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81lpcxpresso55s28_i2s_interrupt_transfer%20%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3ELPC55S28%EF%BC%88%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%EF%BC%89%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%893%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCLK%E3%81%AE%E3%81%BF%E3%80%81%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AASYSCON%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%2F*%20Attach%20PLL%20clock%20to%20MCLK%20for%20I2S%2C%20no%20divider%20*%2F%0A%20%20%20%20CLOCK_AttachClk(kPLL0_to_MCLK)%3B%0A%20%20%20%20SYSCON-%26gt%3BMCLKDIV%20%3D%20SYSCON_MCLKDIV_DIV(0U)%3B%0A%20%20%20%20SYSCON-%26gt%3BMCLKIO%20%20%3D%201U%3B%0A%0A%20%20%20%20CLOCK_SetClkDiv(kCLOCK_DivPll0Clk%2C%200U%2C%20true)%3B%0A%20%20%20%20CLOCK_SetClkDiv(kCLOCK_DivPll0Clk%2C%201U%2C%20false)%3B%0A%0A%20%20%20%20%2F*!%26lt%3B%20Switch%20PLL0%20clock%20source%20selector%20to%20XTAL16M%20*%2F%0A%20%20%20%20%2F*%20I2S%20clocks%20*%2F%0A%20%20%20%20CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM6)%3B%0A%20%20%20%20CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM7)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20SYSCON-%26gt%3BMCLKDIV%20%3D%20SYSCON_MCLKDIV_DIV(0U)%3B%0A%20%20%20%20SYSCON-%26gt%3BMCLKIO%20%20%3D%200U%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FDIV%3E%0A%3CDIV%3ELPC55S28%E3%81%A7%E3%81%AF%E3%80%81BCLK%E3%81%A8WS%E3%81%AB%E6%96%B9%E5%90%91%E8%A8%AD%E5%AE%9A%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Flexcomm%20I2S%E3%81%8C%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%B8%8D%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E4%BE%A1%E5%80%A4%E3%81%AF%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%82%88%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E3%83%8F%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%81%E3%83%A3%E3%83%B3%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
