 magicoe_niu
			magicoe_niu
		@william_jiang would you mind assign a guy support this case who knows Ethernet IP well?
The end customer is Microsoft
Hi Magicoe,
any update on this topic?
is there any special requirement for enabling CBS?
we run traditional iperf test on queue enabled CBS, and expect the throughput are limited by the idle slope. Is that reasonable?
 xiangjun_rong
			xiangjun_rong
I do not think that the Ethernet module of LPC54018 supports credit based shaper.
Hope it can help you
XiangJun Rong
 xiangjun_rong
			xiangjun_rong
		Hi, Wang,
Can you clarify your requirement? do you hope that NXP engineer can help review your code, or you do not know how to use CBS feature of ethernet and hope to get support.
Pls clarify your requirements.
XiangJun Rong
 xiangjun_rong
			xiangjun_rong
		Hi, Wang,
This is the AE reply "LPC54018 supports CBS", but we have not the code to support the feature in SDK driver. I am sorry.
XiangJun Rong
 xiangjun_rong
			xiangjun_rong
Obviously, from the UM11060.pdf, the LPC54018 supports CBS, I will create a ticket for AE team, pls clarify your requirements so that the AE team engineer can help you
If you require us to review the code, pls post it here or send to my personal Email if it is confidential.
XiangJun Rong
 xiangjun_rong
			xiangjun_rong
I tried to contact you, but it appears that your Email address has issue. Pls check if the spelling is correct.
Xiangjun Rong
 xiangjun_rong
			xiangjun_rong
		Hi, Wang,
I appologize for the wrong information, I am not familiar with the CBS (credit based shaper) protocol.
We will give you a response after we discuss with AE team engineers.
XiangJun Rong
