lpc4078 keil error
lpc4078 keil error
1,636 次查看
vine
hi i am new to nxp, using keil ide but getting errors below ,
- ARMLMD_LICENSE_FILE: unset
- LM_LICENSE_FILE: unset
- ARM_PRODUCT_DEF: unset
- ARM_PRODUCT_PATH: unset
- ARM_TOOL_VARIANT: unset
how can i resolve them , could someone share any guide to resolve the same. does it require a license .thanks
1,625 次查看
frank_m
Senior Contributor III
Yes, Keil uVision requires a licence. There used to be a free licence with limitations as well, check the Keil websites.
This sounds like your installation is not correct, or failed for some reason.
I suggest to consult the Keil support and/or the Keil forum, they are in a much better position to help you.
