lpc1343 value error
lpc1343 value error
3,126件の閲覧回数
googcheng
i am starting to maintain an old IAR project
there is a global variable, volatile dali_terminal_t terminal_arr[64] = {0};
 terminal_arr is about 768 bytes.
below figure is before the statement: terminal_arr[addr].group_low = backcmd;   // backcmd is 0x86
after run the statement, group_low value has lost.
im new to LPC , dont know how to debug it and so hope you could give a hand.
ラベル(3)
4 返答(返信)
2,923件の閲覧回数
jeremyzhou
Hi jay ch,
I'd like to know which IDE you use, and the version of it.
TIC
2,923件の閲覧回数
googcheng
IAR 7.80
2,923件の閲覧回数
jeremyzhou
Hi jay ch,
I will check it later, I think there's an issue about the IDE, maybe you can also seek for some support from the IAR via the https://www.iar.com/support/#!?tab=resources
TIC
2,923件の閲覧回数
googcheng
thanks for your support! big possible, we confirm the data still is right by Serial Interface
