lpc1343 value error
lpc1343 value error
3,040 次查看
googcheng
i am starting to maintain an old IAR project
there is a global variable, volatile dali_terminal_t terminal_arr[64] = {0};
 terminal_arr is about 768 bytes.
below figure is before the statement: terminal_arr[addr].group_low = backcmd;   // backcmd is 0x86
after run the statement, group_low value has lost.
im new to LPC , dont know how to debug it and so hope you could give a hand.
标签 (3)
4 回复数
2,837 次查看
jeremyzhou
Hi jay ch,
I'd like to know which IDE you use, and the version of it.
TIC
2,837 次查看
googcheng
IAR 7.80
2,837 次查看
jeremyzhou
Hi jay ch,
I will check it later, I think there's an issue about the IDE, maybe you can also seek for some support from the IAR via the https://www.iar.com/support/#!?tab=resources
TIC
2,837 次查看
googcheng
thanks for your support! big possible, we confirm the data still is right by Serial Interface
