lpc1227 SPI master mode problem
1,793件の閲覧回数
lpcware
Content originally posted in LPCWare by yeefoowang on Thu Oct 01 14:21:01 MST 2015
Using lpc1227 SPI in master mode, lpc1227 sends out clock pulses correctly, but the data bits are sent out on MISO pin. I initialized the pin as an input pin. As soon as I enable the SPI master mode, the data bits are sent at thisMISO pin!!!
What did I do wrong?
2 返答(返信)
1,750件の閲覧回数
lpcware
Content originally posted in LPCWare by yeefoowang on Fri Oct 02 11:04:58 MST 2015
I apologized.
I mislabeled the MISO and MOSI lines.
The lpc1227 SPI master mode is working fine.
This post should be deleted.
1,750件の閲覧回数
lpcware
Content originally posted in LPCWare by yeefoowang on Fri Oct 02 07:45:15 MST 2015
My question is:
Why does lpc1227 SPI master mode send data out at SSP-MISO?
