lpc 2106 CRP?
lpc 2106 CRP?
1,030件の閲覧回数
lpcware
Content originally posted in LPCWare by Kosmas on Thu Jan 15 07:00:46 MST 2015
Hello do anyone have any idea if lpc2106 has crp and how i will enable crp on lpc2106 using IAR?
Thank you for your time and sorry for my bad english! waiting suggestions.
1,003件の閲覧回数
lpcware
Content originally posted in LPCWare by embd02161991 on Wed Jan 28 23:14:35 MST 2015
Starting with bootloader version 1.53 three levels of CRP are implemented on the LPC2106/01. LPC2106/00 has no CRP.
A number of application notes are on CRP. Please refer to the below links. The same procedure applies to LPC2106/01.
http://www.nxp.com/documents/application_note/AN11581.zip
http://www.lpcware.com/content/nxpfile/an10851-crp-example-source-code
http://www.nxp.com/documents/application_note/AN10968.pdf
NXP Technical Support
