is42s16800
is42s16800
christianpeterk
Using LPC54605 and connected a SDRAM: is42s16800, and using MCUXpresso. Does any body have a working fsl_emc.c for that device?
victorjimenez
Hello Christian Peter Koch,
Unfortunately, for that specific memory we don't have an example. The evaluation board for the LPC54608 comes with Winbond 128Mb W9812G6JB-6I SDRAM (Micron MT48LC8M16A2B4 used on all revisions up to Rev C and some Rev D.). You can use the example that we provide in the SDK for this evaluation board along with the following application note: https://www.nxp.com/docs/en/nxp/application-notes/AN12026.pdf as a starting point for your project with the memory is42s16800. If you find problems while developing this we will be happy to help you!
Hope it helps!
Victor.
