i2c program for lpc11c24
1,254件の閲覧回数
lpcware
Content originally posted in LPCWare by rohit on Fri May 22 03:59:30 MST 2015
can someone post a working i2c program for lpc 11c24.... i have tried the example program ....the output is erroneous....pls help me m using lpc for the first time
thanx...
1,164件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Fri May 22 04:39:50 MST 2015
And again: LPCOpen sample is working  :exmark:
If you are not able to get this sample working you should describe your hardware and describe what you are doing in detail...
