how to set enthernet dma into inner sram
1,123 次查看
lpcware
Content originally posted in LPCWare by gjzxwht on Tue May 20 04:35:42 MST 2014
hardware:lpc1778+sdram+lan8710(phy)
                  cpuclk:100Mhz
                  emcclk:50Mhz
software: ucosiii+lwip(lpcopen_2_10_keil_iar_ea_devkit_1788.zip)
now,i put heap into sdram,and enthernet pack lost severely。when i put heap into inner sram,it is ok.
but inner sram is not enough for heap.i just want put the DMA about enthernet into inner sram.how to set? thank you!
1,110 次查看
lpcware
Content originally posted in LPCWare by gjzxwht on Wed May 21 03:54:03 MST 2014
nobody know?
