fsl_usart.c: How to properly handle RX FIFO overflows, i.e., kStatus_USART_RxError
1,295 次查看
danielholala
Senior Contributor II
on LPC5528/LPC5526/LPC55xx, I'm using the USART driver from the SDK, see
https://github.com/nxp-mcuxpresso/mcuxsdk-core/blob/main/drivers/flexcomm/usart/fsl_usart.c#L1123
The code works properly when requesting to receive single bytes using
USART_TransferReceiveNonBlocking()
It also recovers on RX FIFO overflows by reinitiating reception.
Situation is different when using
with xfer->dataSize  > 1. For example, the receive callback inspects the RX FIFO level and if the RX FIFO level is > 1, it calls  USART_TransferReceiveNonBlocking()  with the exact number of bytes of in the RX FIFO to retrieve these bytes more efficiently, say 10 bytes.
However, if the system is busy handling other interrupts, the RX FIFO might overflow. Then
void USART_TransferHandleIRQ(USART_Type *base, usart_handle_t *handle)
clears the RX FIFO overflow bit, empties the FIFO and calls the callback with kStatus_USART_RxError. All the bytes from the FIFO are therefore discarded and cannot be received any more.
However, it does not reset rxDataSize. So the callback will not be called again until the number of bytes (in the example ten bytes) have been received. Until this, the receive mechanics hangs.
How do you recover from this situation?
Resetting the dataSize by calling USART_TransferReceiveNonBlocking() with xfer->dataSize = 1does not work as the receive mechanics is still in status kUSART_RxBusy.
So I wonder what is the proper way to handle RX FIFO overflows with the SDK drivers.
Thanks.
PS: sorry for the strange text formatting. I tried to markup code so it is easier to read but screwed up.
1,119 次查看
Habib_MS
Hello @danielholala,
I understand that you have an issue with how to clear rxDataSize. From what I can see, the SDK (version 25.09) does not handle this automatically, but you can call the function USART_TransferAbortReceive inside the callback. This function clears the rxDataSize, as shown in the following image:
However, this function also aborts the current transfer, so you will need to resume the transmission manually.
Lef me know if this helps you.
Habib
%3CLINGO-SUB%20id%3D%22lingo-sub-2295145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efsl_usart.c%EF%BC%9A%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E5%A4%84%E7%90%86%20RX%20FIFO%20%E6%BA%A2%E5%87%BA%EF%BC%8C%E5%8D%B3%20kStatus_USART_RxError%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%9C%A8%20LPC5528%2FLPC5526%2FLPC55xx%20%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SDK%20%E4%B8%AD%E7%9A%84%20USART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8F%82%E8%A7%81%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcuxsdk-core%2Fblob%2Fmain%2Fdrivers%2Fflexcomm%2Fusart%2Ffsl_usart.c%23L1123%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcuxsdk-core%2Fblob%2Fmain%2Fdrivers%2Fflexcomm%2Fusart%2Ffsl_usart.c%23L1123%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E4%BD%BF%E7%94%A8%E8%AF%B7%E6%B1%82%E6%8E%A5%E6%94%B6%3CSTRONG%3E%E5%8D%95%E5%AD%97%E8%8A%82%3C%2FSTRONG%3E%E6%97%B6%EF%BC%8C%E8%AF%A5%E4%BB%A3%E7%A0%81%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3E%3CSPAN%3EUSART_TransferReceiveNonBlocking()%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AE%83%E8%BF%98%E8%83%BD%E5%9C%A8%20RX%20FIFO%20%E6%BA%A2%E5%87%BA%E6%97%B6%E9%80%9A%E8%BF%87%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%8E%A5%E6%94%B6%E6%9D%A5%E6%81%A2%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20%20%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3E%3CSPAN%3EUSART_TransferReceiveNonBlocking()%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%8E%3CSTRONG%3Exfer-%26gt%3BdataSize%26gt%3B%201%3C%2FSTRONG%3E.%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%8E%A5%E6%94%B6%E5%9B%9E%E8%B0%83%E4%BC%9A%E6%A3%80%E6%9F%A5%20RX%20FIFO%20%E7%BA%A7%E5%88%AB%EF%BC%8C%E5%A6%82%E6%9E%9C%20RX%20FIFO%20%E7%BA%A7%E5%88%AB%E4%B8%BA%20%26gt%3B%201%EF%BC%8C%E5%88%99%E5%AE%83%E4%BD%BF%E7%94%A8%20RX%20FIFO%20%E4%B8%AD%E7%9A%84%E7%A1%AE%E5%88%87%E5%AD%97%E8%8A%82%E6%95%B0%E8%B0%83%E7%94%A8%20%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3Eusart_transferReceiveNonBlocking%20()%3C%2FFONT%3E%EF%BC%8C%E4%BB%A5%E6%9B%B4%E6%9C%89%E6%95%88%E5%9C%B0%E6%A3%80%E7%B4%A2%E8%BF%99%E4%BA%9B%E5%AD%97%E8%8A%82%EF%BC%8C%E6%AF%94%E5%A6%82%2010%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E7%B3%BB%E7%BB%9F%E5%BF%99%E4%BA%8E%E5%A4%84%E7%90%86%E5%85%B6%E4%BB%96%E4%B8%AD%E6%96%AD%EF%BC%8CRX%20FIFO%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%BA%A2%E5%87%BA%E3%80%82%E9%82%A3%E4%B9%88%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EUSART_TransferHandleIRQ%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EUSART_Type%3C%2FSPAN%3E%3CSPAN%3E*%E5%9F%BA%E7%AB%99%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%3Eusart_handle_t%3C%2FSPAN%3E%3CSPAN%3E*handle)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B8%85%E9%99%A4%20RX%20FIFO%20%E6%BA%A2%E5%87%BA%E4%BD%8D%EF%BC%8C%E6%B8%85%E7%A9%BA%20FIFO%20%E5%B9%B6%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3E%20%3CSTRONG%3Ekstatus_USART_RXError%3C%2FSTRONG%3E%20%E8%B0%83%E7%94%A8%E5%9B%9E%E8%B0%83%E3%80%82%20%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9D%A5%E8%87%AA%20FIFO%20%E7%9A%84%E6%89%80%E6%9C%89%E5%AD%97%E8%8A%82%E9%83%BD%E5%B0%86%E8%A2%AB%E4%B8%A2%E5%BC%83%EF%BC%8C%E6%97%A0%E6%B3%95%E5%86%8D%E6%8E%A5%E6%94%B6%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%83%E4%B8%8D%E4%BC%9A%20RESET%20%3CSTRONG%3ErxData%3C%2FSTRONG%3E%20Size%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E6%94%B6%E5%88%B0%E5%AD%97%E8%8A%82%E6%95%B0%EF%BC%88%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E4%B8%BA%E5%8D%81%E5%AD%97%E8%8A%82%EF%BC%89%E4%B9%8B%E5%89%8D%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%86%8D%E6%AC%A1%E8%B0%83%E7%94%A8%E5%9B%9E%E8%B0%83%E3%80%82%E5%9C%A8%E6%AD%A4%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%8E%A5%E6%94%B6%E6%9C%BA%E5%88%B6%E4%B8%80%E7%9B%B4%E5%A4%84%E4%BA%8E%E5%81%9C%E6%BB%9E%E7%8A%B6%E6%80%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%BB%8E%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%AD%E6%81%A2%E5%A4%8D%E8%BF%87%E6%9D%A5%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%3CFONT%20face%3D%22verdana%2Cgeneva%22%3E%20xf%40%40%20er-%26gt%3B%20dataSize%20%3D%201%3C%2FFONT%3E%3CFONT%20face%3D%22helvetica%22%3E%20%E8%B0%83%E7%94%A8%3C%2FFONT%3E%3CFONT%20face%3D%22verdana%2Cgeneva%22%3E%20usart_transferReceiveNonBlocking%20()%3C%2FFONT%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E6%9D%A5%E9%87%8D%E7%BD%AE%E6%95%B0%E6%8D%AE%E5%A4%A7%E5%B0%8F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%8E%A5%E6%94%B6%3C%2FSPAN%3E%20%E6%9C%BA%E5%88%B6%E4%BB%8D%E5%A4%84%E4%BA%8E%E7%8A%B6%E6%80%81%20kusart_rx%20Busy%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%BF%E7%94%A8%20SDK%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A4%84%E7%90%86%20RX%20FIFO%20%E6%BA%A2%E5%87%BA%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%96%B9%E6%B3%95%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%99%84%E6%B3%A8%EF%BC%9A%E6%8A%B1%E6%AD%89%E6%96%87%E5%AD%97%E6%A0%BC%E5%BC%8F%E6%9C%89%E4%BA%9B%E5%A5%87%E6%80%AA%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E6%A0%87%E6%B3%A8%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E5%AE%B9%E6%98%93%E9%98%85%E8%AF%BB%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E6%90%9E%E7%A0%B8%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_usart.c%3A%20How%20to%20properly%20handle%20RX%20FIFO%20overflows%2C%20i.e.%2C%20kStatus_USART_RxError%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F139806%22%20target%3D%22_blank%22%3E%40danielholala%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E4%BD%A0%E5%AF%B9%E5%A6%82%E4%BD%95%E6%B8%85%E9%99%A4%20rxDataSize%20%E6%9C%89%E7%96%91%E9%97%AE%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8CSDK%EF%BC%8825.09%20%E7%89%88%EF%BC%89%E4%B8%8D%E4%BC%9A%E8%87%AA%E5%8A%A8%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%9B%9E%E8%B0%83%E4%B8%AD%E8%B0%83%E7%94%A8%20USART_TransferAbortReceive%20%E5%87%BD%E6%95%B0%E3%80%82%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E8%AF%A5%E5%87%BD%E6%95%B0%E5%B0%86%E6%B8%85%E9%99%A4%20rxDataSize%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Habib_MS_0-1768941580726.png%22%20style%3D%22width%3A%20579px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Habib_MS_0-1768941580726.png%22%20style%3D%22width%3A%20579px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373550i708D75AE9DD86ADA%2Fimage-dimensions%2F579x273%3Fv%3Dv2%22%20width%3D%22579%22%20height%3D%22273%22%20role%3D%22button%22%20title%3D%22Habib_MS_0-1768941580726.png%22%20alt%3D%22Habib_MS_0-1768941580726.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%AF%A5%E5%8A%9F%E8%83%BD%E4%B9%9F%E4%BC%9A%E7%BB%88%E6%AD%A2%E5%BD%93%E5%89%8D%E4%BC%A0%E8%BE%93%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E9%9C%80%E8%A6%81%E6%89%8B%E5%8A%A8%E6%81%A2%E5%A4%8D%E4%BC%A0%E8%BE%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3CBR%20%2F%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E
