flash memory programming
Content originally posted in LPCWare by xavas on Tue May 10 13:11:07 MST 2016
Hi everybody!
I would like to know how to transfer my code to LPC15xx FLASH MEMORY. I know one way to do that is by means ISP resource. But I need to do that by J-TAG (such as LPC176x) or USB interfaces. Does anybody know if this is possible to this family?
Thanx in advance.
bump
Content originally posted in LPCWare by xavas on Fri May 13 10:15:48 MST 2016
Hi R2D2!
I´ve browsed the first link. Too many information. Pretty good!
I´m gonna check the second one. In fact I use KEIL5 so, I´ve to see if the whole environment will work nicely! I hope so. Let me check the YOUTUBE´s link.
Content originally posted in LPCWare by R2D2 on Fri May 13 07:53:43 MST 2016
Quote: xavas
...get the proper infos on how-to-do that.
:quest:
https://www.lpcware.com/lpcxpresso
Especially:
http://www.youtube.com/watch?v=NW7GmsMcrKc
Content originally posted in LPCWare by xavas on Fri May 13 07:43:53 MST 2016
Hi R2D2!
Thanx for your tip!
I will get the board in order to get the proper infos on how-to-do that.
Xavier
Content originally posted in LPCWare by R2D2 on Tue May 10 13:15:36 MST 2016
Just use your debugger  :O
https://www.embeddedartists.com/products/lpcxpresso/lpclink2.php
