flash memory programming
2,245 次查看
Content originally posted in LPCWare by xavas on Tue May 10 13:11:07 MST 2016
Hi everybody!
I would like to know how to transfer my code to LPC15xx FLASH MEMORY. I know one way to do that is by means ISP resource. But I need to do that by J-TAG (such as LPC176x) or USB interfaces. Does anybody know if this is possible to this family?
Thanx in advance.
5 回复数
2,175 次查看
bump
2,175 次查看
Content originally posted in LPCWare by xavas on Fri May 13 10:15:48 MST 2016
Hi R2D2!
I´ve browsed the first link. Too many information. Pretty good!
I´m gonna check the second one. In fact I use KEIL5 so, I´ve to see if the whole environment will work nicely! I hope so. Let me check the YOUTUBE´s link.
2,175 次查看
Content originally posted in LPCWare by R2D2 on Fri May 13 07:53:43 MST 2016
Quote: xavas
...get the proper infos on how-to-do that.
:quest:
https://www.lpcware.com/lpcxpresso
Especially:
http://www.youtube.com/watch?v=NW7GmsMcrKc
2,175 次查看
Content originally posted in LPCWare by xavas on Fri May 13 07:43:53 MST 2016
Hi R2D2!
Thanx for your tip!
I will get the board in order to get the proper infos on how-to-do that.
Xavier
2,175 次查看
Content originally posted in LPCWare by R2D2 on Tue May 10 13:15:36 MST 2016
Just use your debugger  :O
https://www.embeddedartists.com/products/lpcxpresso/lpclink2.php
