ethernet for beginner?
1,718件の閲覧回数
saideva293
hi,
im currently working on lpc54628,In this, i started working on ethernet. Here my problem is i dont know how to code for ethernet in a flow and then i searched many examples but i cant understand the program so i decided to do the code using the registers.so i need a perfect program to understand ethernet kindly help me out.
thank you!
1,620件の閲覧回数
soledad
I suggest downloading the MCUXpresso SDK for the LPC54628. After download it, you will find some examples that you can use as reference.
In addition, I suggest download the SDK documentation in order to check the API references.
I hope this helps, have a nice day!
Soledad
