connect pin LPC1788
connect pin LPC1788
970件の閲覧回数
Aleks710
Hi. What capacity of capacitors connect  to pin  VDD, VSS   LPC1788FBD208, LPC1788FET208  (100nF or 10nF or other)? What capacity of capacitors connect  to pin  VDD-REG3V3, VSS-REG   LPC1788FBD208, LPC1788FET208  (100nF or 10nF or other)? How many capacitors connect   to pin  VDD-VSS; VDD-REG3V3-VSS-REG (capacitor for each VDD, VSS  pin or other)? What is the connection scheme to pins VREFP, VDDA? What is the connection scheme to pin VBAT? What is the connection scheme to pins X1-X2? What is the connection scheme to pins RTCX1- RTCX2? If you have an Application Notes on this topic, please send it.
874件の閲覧回数
Aleks710
I saw the scheme LPC1788 OEM Board, but it doesn't tell me which capacitors  to install(there are 18 capacitors in total on the scheme, and 13 pairs of pin VDD, VDD-REG3V3). What capacity of capacitors connect  to pin  VDD, VSS   LPC1788FBD208, LPC1788FET208  (100nF or 10nF or other)?  What capacity of capacitors connect  to pin  VDD-REG3V3, VSS-REG   LPC1788FBD208, LPC1788FET208  (100nF or 10nF or other)? How many capacitors connect   to pin  VDD-VSS; VDD-REG3V3-VSS-REG (capacitor for each VDD, VSS  pin or other)? Do I need a ferrite bead between VSS  and VSSA?  On my device fcpu=120MHz, use Ethernet, USB, RTC, 3 UART, 1 CAN, 1 I2C, EMC for SDRAM and NAND Flash, GPIO
907件の閲覧回数
luis_maravilla
Hello
For the capacitor values and quantities, you could review our partner’s available LPC1788 Developer Kit information as a reference. Please note that this information is provided solely for guidance. Embedded Artists AB | Partner Profile | NXP Semiconductors Inc.
The image in Figure 8 on LPC178x Datasheet shows the power distribution, could you confirm is this the connection scheme that you need? Or could you help us share details about the information that you need?
-The chapter 3.8.2 in UM10470, Table 43 and Figure 10 can guide you in the connection and value specifications.
-Refer to UM10470 Chapter 29.4 Figure 155
Best Regards, Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2316481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%8E%A5%E7%B6%9A%E3%83%94%E3%83%B3LPC1788%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--470598041%22%20id%3D%22toc-hId--470571380%22%20id%3D%22toc-hId--470571380%22%20id%3D%22toc-hId--470571380%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82LPC1788FBD208%E3%80%81LPC1788FET208%20%E3%81%AE%E3%83%94%E3%83%B3%20VDD%E3%80%81VSS%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%AE%E5%AE%B9%E9%87%8F%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%20(100nF%20%E3%81%BE%E3%81%9F%E3%81%AF%2010nF%20%E3%81%AA%E3%81%A9)%3F%E3%83%94%E3%83%B3%20VDD-REG3V3%E3%80%81VSS-REG%20LPC1788FBD208%E3%80%81LPC1788FET208%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%AE%E5%AE%B9%E9%87%8F%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%20(100nF%20%E3%81%BE%E3%81%9F%E3%81%AF%2010nF%20%E3%81%AA%E3%81%A9)%3FVDD-VSS%E3%80%81VDD-REG3%E3%80%81V3-VSS-REG%20%E3%83%94%E3%83%B3%20(%E5%90%84%20VDD%E3%80%81VSS%20%E3%83%94%E3%83%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%94%E3%83%B3%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5)%20%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3FVREFP%E3%80%81VDDA%20%E3%83%94%E3%83%B3%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3FVBAT%20%E3%83%94%E3%83%B3%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%94%E3%83%B3%20X1-X2%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%94%E3%83%B3%20RTCX1%20%EF%BD%9E%20RTCX2%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FH2%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20connect%20%20pin%20%20LPC1788%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%AE%E5%80%A4%E3%81%A8%E6%95%B0%E9%87%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AE%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%20LPC1788%20%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%82%E3%81%8F%E3%81%BE%E3%81%A7%E3%82%82%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fconnect%2FdisplayPartnerProfile.sp%3FpartnerId%3D10340%26amp%3BofferingId%3D16240%23%3A~%3Atext%3DDEVELOPMENT%2520BOARDS%2FDESIGNS-%2CLPC1788%2520Developer%2527s%2520Kit%2C-Embedded%2520Artists%2527%2520LPC1788%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEmbedded%20Artists%20AB%20%7C%20%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%20%7C%20NXP%20Semiconductors%20Inc.%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELPC178x%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E5%9B%B3%208%20%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%E9%9B%BB%E5%8A%9B%E9%85%8D%E5%88%86%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%94%E3%83%B3%20X1-X2%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E-UM10470%20%E3%81%AE%203.8.2%20%E7%AB%A0%E3%80%81%E8%A1%A8%2043%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E5%9B%B3%2010%20%E3%81%AB%E3%81%AF%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%A8%E5%80%A4%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%94%E3%83%B3%20RTCX1%20%EF%BD%9E%20RTCX2%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E6%96%B9%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E-UM10470%E7%AC%AC29.4%E7%AB%A0%E5%9B%B3155%E3%82%92%E5%8F%82%E7%85%A7%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20connect%20%20pin%20%20LPC1788%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--470512696%22%20id%3D%22toc-hId-2016941453%22%3ELPC1788%20OEM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%A0%E3%81%AB%E3%81%AF%E5%90%88%E8%A8%88%2018%20%E5%80%8B%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%A8%E3%80%81%E3%83%94%E3%83%B3%20VDD%E3%80%81VDD-REG3V3%20%E3%81%AE%2013%20%E7%B5%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82LPC1788FBD208%E3%80%81LPC1788FET208%20%E3%81%AE%E3%83%94%E3%83%B3%20VDD%E3%80%81VSS%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%AE%E5%AE%B9%E9%87%8F%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%20(100nF%20%E3%81%BE%E3%81%9F%E3%81%AF%2010nF%20%E3%81%AA%E3%81%A9)%3F%E3%83%94%E3%83%B3%20VDD-REG3V3%E3%80%81VSS-REG%20LPC1788FBD208%E3%80%81LPC1788FET208%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%AE%E5%AE%B9%E9%87%8F%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%20(100nF%20%E3%81%BE%E3%81%9F%E3%81%AF%2010nF%20%E3%81%AA%E3%81%A9)%3FVDD-VSS%E3%80%81VDD-REG3%E3%80%81V3-VSS-REG%20%E3%83%94%E3%83%B3%20(%E5%90%84%20VDD%E3%80%81VSS%20%E3%83%94%E3%83%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%94%E3%83%B3%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5)%20%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%87%E3%83%B3%E3%82%B5%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3FVSS%20%E3%81%A8%20VSSA%20%E3%81%AE%E9%96%93%E3%81%AB%E3%83%95%E3%82%A7%E3%83%A9%E3%82%A4%E3%83%88%20%E3%83%93%E3%83%BC%E3%82%BA%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81fcpu%3D120MHz%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%80%81USB%E3%80%81RTC%E3%80%813%E3%81%A4%E3%81%AEUART%E3%80%811%E3%81%A4%E3%81%AECAN%E3%80%811%E3%81%A4%E3%81%AEI2C%E3%80%81SDRAM%E3%81%A8NAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%E3%81%AEEMC%E3%80%81GPIO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FH2%3E%3C%2FLINGO-BODY%3E
