best USBD mode for transceiving low rate data
Content originally posted in LPCWare by dizgah on Sat Apr 02 21:05:29 MST 2016
Hi every one,I'm trying to use lpc11u68 for transceiving data between PC as host & MCU as a slave,data rate is about some KBPS,plug & play ability(without drivers limitations) is desired but not necessary,Simple initialing is desired too.
with this specifications which mode (CDC,HID,...) is desired?
EDIT: there is another usbd_rom_libusb mode in the LPCOPEN,seems is simpler to use for data transferring,in this state MCU recognized by PC in which mode(HID,CDC,...)?is this recommended for data transferring? and support plug & play or not ?
with best regards.
bump
