asm "jump" in codeRed
1,010 次查看
Content originally posted in LPCWare by leluno on Wed Apr 22 01:37:15 MST 2015
with a watchdog-timer the code first should go to the beginnin of the while(1)-loop, second to reset.
on AVR it works like this:
if(zl_sec_wdg==25){asm("jmp label");}
if(zl_sec_wdg>50){asm("jmp 0");}
jmp 0 equals NVIC_SystemReset()
how can I make asm("jmp label" in codeRed?
thanks for helping
992 次查看
Content originally posted in LPCWare by whitecoe on Wed Apr 22 02:09:50 MST 2015
Sounds like you want the standard C "continue" statement, described in any book on C or on lots of webpages, for example:
http://www.codingunit.com/c-tutorial-for-loop-while-loop-break-and-continue
HTH!
