Writing and reading a array of data from Flash memory
2,342 次查看
sridharan
I am using  LPC11c24 Xpresso board, My query is how to write a array of data(Max 8bytes) into Flash memory and read the same when required after Power reset .Is there any API or any sample code available. Can anyone help me in this regards
2,188 次查看
jeremyzhou
Hi sridharan j ,
for the opportunity to serve you.
The LPC MCUs IAP commands don'tsupport to read the data from the flash, however I was wondering if you can describe the goad you want to achieve, we may find another way to implement it.
TIC
2,188 次查看
sridharan
Hi JeremZhou,
I am able to write and read page wise with block number. I used API.c and API.h files to achieve this.
Thank you for the support
Sridharan J
