Where is the function 'i2c_set_bitrate' defined?
1,288 次查看
Content originally posted in LPCWare by coolriza on Mon Sep 07 02:01:48 MST 2015
Hello.
I'm now analyzing source codes of NXP Quick Jack solution (LPC812M is employed for evaluation board).
And I'm curious about function body of 'i2c_set_bitrate'.
I can find the declaration of function 'i2c_set_bit' in rom_i2c_8xx.h, but I can't find a function body of 'i2c_set_bitrate' anywhere.
Could you give me an advice?
Thanks.
1,269 次查看
Content originally posted in LPCWare by embd02161991 on Wed Sep 09 09:02:36 MST 2015
'i2c_set_bitrate' is an API call to the ROM that configures the I2C duty-cycle registers (SCLH and SCLL). Hence the source of the function call is not present in the examples.
NXP Technical Support
