What tools are used to convert HTML into C language arrays
4,886 次查看
JohnDZhang
I used LPC54628, designed web server. I found SDK lwip_httpsrv. I can modify HTML file, but which tools can convert HTML to C language arrays? Many thanks!
4,708 次查看
xiangjun_rong
This is AE reply:
in SDK's "\middleware\lwip\src\apps\http\makefsdata" folder, there is makefsdata source code for convert HTML to C, customer need use Visual Studio to compile it to exe or other compiler tools for PC OS.
Visual Studio project under folder "middleware\lwip\contrib\ports\win32\msvc"
Hope it can help you
XiangJun Rong
5 回复数
4,831 次查看
xiangjun_rong
For HTTP server, it uses CGI protocol.
Pls search the CGI protocol for the http server.
XiangJun Rong
4,816 次查看
JohnDZhang
Many thanks for your reply! What I mean is how to convert HTML files into arrays in C language, not how to parse CGI.
For example, the auth.xml in my picture has been converted to "static const unsigned char httpsrv_fs_webpage_auth_html[]"
4,804 次查看
xiangjun_rong
it appears that the https://realtimelogic.com is used.
Anyway I have asked the AE team, I will update after I get reply.
XiangJun Rong
4,709 次查看
xiangjun_rong
This is AE reply:
XiangJun Rong
4,800 次查看
JohnDZhang
Thank you very much!
