What's the easiest way to execute a reset?
3,318 次查看
chrispflieger
Is there a command to reset the MCU?
3,165 次查看
chrispflieger
Going off of Erich's tip, I went looking for that register and found this little gem in the LPCopen code:
NVIC_SystemReset()
Sweet.
3,166 次查看
chrispflieger
NVIC_SystemReset()
Sweet.
3,165 次查看
BlackNight
ARM Cortex M has a way to trigger a reset with writing to the AIRCR register.
See How to Reset an ARM Cortex-M with Software | MCU on Eclipse
I hope this helps,
Erich
