What is the recommended microcontroller series that replaces the LPC1768 series?
Applied123
Anyone please suggest exact pin to pin replacement for LPC17xx series.
I have existing designs, modify hardware is a problem, but I have a lot of code (tons) using LPC2148 peripherals (UART, I2C, Timers, ...), which new family is peripheral-software compatible?.
What series recommended for new designs has roughly equivalent capability (Memory size, speed, peripherals, etc.)?
jonathansmith
I have the same question, and appreciate it's now almost 5 years later.
Which series of microcontrollers should I be looking at to use for new designs?
ZhangJennie
the LPC1768 is a replacement for the LPC2368. and the LPC1769 is a replacement for the LPC1768. The only difference is the max clock frequency (120Mhz) . A replacement with less memory is the LPC1766.LPC4078 is an option for LPC176x replacement.(http://www.nxp.com/products/microcontrollers/core/cortex_m4_m4f/LPC4078FBD100.html )
Please note LPC4078 release time is 2013, 15 years longevity.
Our Recommendation is LPC546xx or LPC540xx MCUs series, based on Cortex M4 core at 220MHz (with optional secondary Cortex M0+ core), similar peripherals, up to 512KB Flash and up to 200KB RAM.Please check more information in the following link:https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/lpc-corte...
LPC546xx and LPC540xx are not pin to pin replacement of LPC17xx
Have a nice day,
Jun Zhang
%3CLINGO-SUB%20id%3D%22lingo-sub-1237759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhat%20is%20the%20recommended%20microcontroller%20series%20that%20replaces%20the%20LPC1768%20series%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1237759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EAnyone%20please%20suggest%20exact%20pin%20to%20pin%20replacement%20for%20LPC17xx%20series.%3C%2FP%3E%3CP%3EI%20have%20existing%20designs%2C%20modify%20hardware%20is%20a%20problem%2C%20but%20I%20have%20a%20lot%20of%20code%20(tons)%20using%20LPC2148%20peripherals%20(UART%2C%20I2C%2C%20Timers%2C%20...)%2C%20which%20new%20family%20is%20peripheral-software%20compatible%3F.%3C%2FP%3E%3CP%3EWhat%20series%20recommended%20for%20new%20designs%20has%20roughly%20equivalent%20capability%20(Memory%20size%2C%20speed%2C%20peripherals%2C%20etc.)%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20the%20recommended%20microcontroller%20series%20that%20replaces%20the%20LPC1768%20series%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20the%20same%20question%2C%20and%20appreciate%20it's%20now%20almost%205%20years%20later.%3C%2FP%3E%3CP%3EWhich%20series%20of%20microcontrollers%20should%20I%20be%20looking%20at%20to%20use%20for%20new%20designs%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1237781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20the%20recommended%20microcontroller%20series%20that%20replaces%20the%20LPC1768%20series%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1237781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3Ethe%20LPC1768%20is%20a%20replacement%20for%20the%20LPC2368.%20and%20the%20LPC1769%20is%20a%20replacement%20for%20the%20LPC1768.%20The%20only%20difference%20is%20the%20max%20clock%20frequency%20(120Mhz)%20.%20A%20replacement%20with%20less%20memory%20is%20the%20LPC1766.LPC4078%20is%20an%20option%20for%20LPC176x%20replacement.(%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fmicrocontrollers%2Fcore%2Fcortex_m4_m4f%2FLPC4078FBD100.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fproducts%2Fmicrocontrollers%2Fcore%2Fcortex_m4_m4f%2FLPC4078FBD100.html%3C%2FA%3E%20)%3CBR%20%2F%3EPlease%20note%20LPC4078%20release%20time%20is%202013%2C%2015%20years%20longevity.%3C%2FP%3E%0A%3CP%3EOur%20Recommendation%20is%20LPC546xx%20or%20LPC540xx%20MCUs%20series%2C%20based%20on%20Cortex%20M4%20core%20at%20220MHz%20(with%20optional%20secondary%20Cortex%20M0%2B%20core)%2C%20similar%20peripherals%2C%20up%20to%20512KB%20Flash%20and%20up%20to%20200KB%20RAM.Please%20check%20more%20information%20in%20the%20following%20link%3A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-based-processors-and-mcus%2Flpc-cortex-m-mcus%2Flpc54000-series-cortex-m4-mcus%3AMC_1414576688124%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-based-processors-and-mcus%2Flpc-cortex-m-mcus%2Flpc54000-series-cortex-m4-mcus%3AMC_1414576688124%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELPC546xx%20and%20LPC540xx%20are%20not%20pin%20to%20pin%20replacement%20of%20LPC17xx%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20nice%20day%2C%3C%2FP%3E%0A%3CP%3EJun%20Zhang%3C%2FP%3E%3C%2FLINGO-BODY%3E
