Using SRAM in LPCOpen
2,555件の閲覧回数
vitaliylivnov
Our project is written for the LPC4370 microcontroller using the LPCOpen library. We encountered the following problem: when compiling a project, only a block of 128 KB of RAM is available with a total memory of 282 KB. Please explain how we can use the remaining memory for the needs of global variables?
ラベル(2)
2,428件の閲覧回数
jeremyzhou
Hi Vitaliy Livnov,
It's freely for you place the global variables in the specific area in the RAM via managing the linker file.
To make it, I'd highly recommend you to review the corresponding IDE's user guide.
TIC
2,429件の閲覧回数
jeremyzhou
Hi Vitaliy Livnov,
TIC
2,428件の閲覧回数
vitaliylivnov
Thank you. We used macro __BSS(RAMx) from <cr_section_macros.h> to place our data in different RAM banks.
