Unresponsive LPC5504
1,087件の閲覧回数
lumine01
LPC5504 is giving me headaches. My code is working fine with MCUXpresso IDE and runs flawlessly. However, the moment I power cycle the board, the firmware disappears! The chip becomes completely unresponsive, and I have to re-flash it. I have tried everything, including different LPC5504 boards, various power supplies, and double-checking the boot pins. But nothing seems to work. My Stonegrill restaurant is lacking behind because of this. Is there someone else who faces similar issues?
1,057件の閲覧回数
ErichStyger
Specialist I
Just asking the obvious: are you sure you have programmed the FLASH memory with your application, and that you are *not* running a RAM target?
1,060件の閲覧回数
lumine01
I would really appreciate if someone could help me find a solution since my Stonegril restaurant is suffering because of this.
