USB ROM HID + FreeRTOS problem
Content originally posted in LPCWare by DodigI on Sat Aug 23 03:42:58 MST 2014
my USB ROM HID is working correctly and enumeration is successful.
However, if I only add xTaskCreate(...) in main before or after USB initialization code, without even starting the scheduler, the USB enumeration fails.
What could cause the problem? I have enough heap memory for the thread. I comment xTaskCreate and USB works, uncomment and it fails.
Thanks.
Content originally posted in LPCWare by DodigI on Sat Aug 23 03:59:45 MST 2014
Solved,
xTaskCreate disables interrupts via PRIMASK. vTaskStartScheduler(); clears the PRIMASK...
