USB Mass Storage Host Enumeration
1,560 次查看
Content originally posted in LPCWare by mb1391 on Tue Feb 11 01:49:48 MST 2014
I am using nxpUSBlib v0.98b and LPCExpresso v6.1.0 for USB Mass Storage Host implementation on LPC17xx-40xx.
I have an issue regarding USB Mass Storage Device enumeration using LPCUSBLib.
When the target hardware detects voltage change on USB port, it invokes the enumeration sequence.
I have a USB flash drive to enumerate and I attach it to my hardware in OFF condition.
When I power ON my target hardware, it doesn't detect the voltage change on port and doesn't enumerate.
My application requires this kind of enumeration where there will be a USB flash drive attached and the hardware will have frequent power cycles.
How can this problem be fixed at driver level?
1,492 次查看
Content originally posted in LPCWare by ksufinger on Mon Nov 30 14:10:27 MST 2015
Try calling USB_ResetInterface(0) after the USB host has been initialized, and before your main loop begins.
