USB Documentation
USB Documentation
2,294 次查看
alannilsson
Is there any documentation for the USB stack used in the examples of the SDK?  Are the examples + UM all we get?  Are there plans on providing API documentation for both full speed and high speed host?
2,201 次查看
Carlos_Mendoza
Hi Alan,
You can find the corresponding USB documentation inside the SDK package on the following path:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
2,201 次查看
alannilsson
Thank you!
2,201 次查看
alannilsson
Intended for the LPC546XX area but I can't seem to mark it as such.
2,202 次查看
Carlos_Mendoza
Hi Alan,
Hope it helps!
Carlos Mendoza
