USB Device : VCOM stop working
2,132件の閲覧回数
riteshunde
I am using OM13092 LPCXpresso with LPC54608. While using MCUxpresso with USB example usb_device_cdc_vcom, it was working fine with echo back of byte I was transmitting on port.but suddenly it stopped working. I can view VCOM port in device driver but it doesn't echo back any data.
I tried with following options :
1. Reinstalling vcom port driver
2. Reinstalling MCUXpresso IDE v10.0.0
3. Swapping USB ports on PC
I am using Windows 7 professional, 32 bit OS.
2 返答(返信)
1,935件の閲覧回数
jeremyzhou
Hi ritesh unde,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
I was wondering if you can introduce the steps to replicate the issue.
I'm looking forward to your reply.
TIC
1,935件の閲覧回数
riteshunde
Hi @jeremyzhou,
Solved, there were some com0 drivers installed on my pc, removed those and vcom started to work.
Thanks.
