Two USB Hosts on LPC1788?
lpcware
Content originally posted in LPCWare by deniscavalli on Thu Apr 23 10:17:48 MST 2015
Hi all!
I am trying to use USB ports 1 and 2 of my LPC1788 as hosts at the same time, but with no success.
Anyone has any clue on how to do that?
lpcware
Content originally posted in LPCWare by gopelsk on Fri Jun 26 04:11:25 MST 2015
Hi all,
I'm a new member for this site and forum and now i learning the C++ language.
I had a same problem, I cannot modify any USB sorce code to USB <-> Serial converter.
I found only one source code which implemented the FT232.
https://www.segger.com/ebdownloads.html#eb163
I have an Open1788 dev kit and I got one source code to usb mass storage and I modified but without success.
Can you help someone with a standard USB to Serial Converter source code?
Regards, George
lpcware
Content originally posted in LPCWare by mc on Fri Apr 24 12:52:00 MST 2015
Hi  denis,
Could you please post the details?
Can you also post code here?
