Trusted Platform Module over SPI driver
4,782 次查看
mbressler
We've been hoping to add a Trusted Platform Modules on our new embedded product (based around the LPC54114) to deal with the FIPS 140-2 requirements.
From what I can tell (please correct me if I'm wrong) Trusted Platform Modules all work on some common spec that allows generic TPM drivers on PC and Linux. Is there a TPM over SPI driver for the LPC54114 or similar MCUs?
We're using the LPC54114 via MCUXpresso and the SLB 9670 TPM from Infineon.
标签 (3)
4,047 次查看
mbressler
Problem solved ended up going with WolfTPM, they have a very portable C driver for TPMs that's small enough and designed with microcontrollers in mind.
4,048 次查看
mbressler
4,047 次查看
shaiknisar
Hey Marc Bressler.
I'm currently trying to communicate SLB9670VQ1.2 with STM32F429ZI controller. The TPM standards supported by the TPM chip i use is TPM1.2. I'm trying to go through the WolfTPM and trying build one. My question is how did you use the WolfTPM? Can you please share the build?
