TreeView Problem !
TreeView Problem !
1,277件の閲覧回数
Content originally posted in LPCWare by arash0092 on Mon Jul 29 16:01:09 MST 2013
I used treeview widget in my application.
Is it supposed to change the selected item when the treeview item clicked?
it is not working as so!
I use touch screen as input device .The board is EALPC1788.
Does anybody have suggestion?
1,234件の閲覧回数
Content originally posted in LPCWare by Wouter on Tue Jul 30 01:27:38 MST 2013
I'm not really sure what you mean by: "Is it supposed to change the selected item when the treeview item clicked", but you may want to have a look at the emWin samples:
http://www.segger.com/emwin-samples.html
There are at least three examples (simulator + source code) using the treeview. You can check whether the behavior is the same as in your application and compare the source code.
