Sleep mode current increases when i2c wakeup source used
VasuVirpariya
I used the SDK's example (power_mode_switch_lpc) for exercising power-down mode. I added support for i2c wakeup in power-down mode. The issue that we are facing is as per below.
1) Entering power-down mode from the UART menu.
2) Power down mode current = 14 uA.
3) Wake up from the I2C.
4) Entering power-down mode from the UART menu.
5) Power down mode current = 67 uA.
 I have attached the project below. What could be going wrong in second time?
Labels (2)
VasuVirpariya
It is LPC804. I am using the LPCxpresso804 kit.
What I am wondering is why first time it is consuming 14uA current and the second time onward it is taking 67uA. The attached firmware can be run on the LPCxpresso804 kit.
xiangjun_rong
Because you use I2C as slave to wake-up the LPC, I suppose that you activate  SRAM block, as you know that each SRAM block requires a lot power.
Pls check the SRAM block power up or down in PDRUNCFG register for your different configuration
BTW, can you tell us the part number of LPC?
XiangJun Rong
