SRAM retain after software reset
Content originally posted in LPCWare by MrBool on Fri Aug 14 01:36:32 MST 2015
After NVIC_SystemReset() is the SRAM content retained?
I want to write some magic value to SRAM and make NVIC_SystemReset() then in my bootloader check this value to go in boot mode.
Content originally posted in LPCWare by MrBool on Fri Aug 14 02:11:54 MST 2015
I have found:
https://www.lpcware.com/content/faq/after-software-reset-wd-reset-bod-reset-sram-content-retained
I just want to check only one variable  in SRAM. I use for that SRAM section not used in software. In link "LPC1769 - keep settings after restart of program" there is example with variable retained after software reset.
So is it possible or not?
Content originally posted in LPCWare by R2D2 on Fri Aug 14 01:59:16 MST 2015
No  :O
Forum search:
https://www.lpcware.com/content/forum/lpc1769-keep-settings-after-restart-of-program
