SPIFI CS
SPIFI CS
1,672 次查看
cychen88
LPC54618 SPIFI How to user other CS ?because i have tow QSPI Flash.
标签 (3)
1,605 次查看
Alexis_A
Hi Chen Guo.
Unfortunately, the QSPI module only has a single CS, I think you could implement this using a GPIO but you will need to have in count that the CS will be enabled every time you send a command and if there's timing restrictions in your memory regarding the CS.
Let me know if this helps you.
Alexis Andalon
