SPI boot clock frequency
902 次查看
Content originally posted in LPCWare by jond on Wed Aug 19 01:50:31 MST 2015
We're considering a switch from NAND boot to SPI EEPROM boot.
In the LPC32x0 user manual (UM10326), figure 131 (SPI boot procedure), fsck is defined as fosc/2.
As 'fosc' isn't referenced anywhere else in the document, we would like to confirm what it is before we select an EEPROM part and modify the board layout.
Is fosc just the external crystal oscillator frequency? For example if we use a 13MHz crystal for SYSX then will the boot SPI clock be 6.5MHz?
Many thanks,
Jon.
0 回复数
