SDXC LPC4357
SDXC LPC4357
4,301 次查看
lilipeeeee
      I need the sdxc library for lpc 4357  use a 64GB sd card for my project。Does this device not support SDXC mode?????
Can not open :
sdxc library for lpc 43s67
Bugreport: SD-Card on LPC18xx, LPC43xx, LPC17xx | www.LPCware.com
4,220 次查看
ZhangJennie
HI lilipeeeee
By checking,  LPC4357 does not support 64GB SDXC cards. The fix only works for 32GB SDHC.
Sorry for the inconvinience.
Have a nice day,
Jun Zhang
9 回复数
4,274 次查看
lilipeeeee
Thank you for your help!
4,288 次查看
ZhangJennie
Hi lilipeeeee,
This link no longer exists.
The bug fix is related an old version lpcopen. lpcopen v3.02 already fixes it.
in sdmmc_18xx_43xx.c there is this:
c_size = prv_get_bits(48, 63, (uint32_t *) g_card_info->card_info.csd) + 1;
To
c_size = prv_get_bits(48, 69, (uint32_t *) g_card_info->card_info.csd) + 1;
32G SD card works well with this fix.
Hope this helps,
Jun Zhang
4,274 次查看
lilipeeeee
4,275 次查看
lilipeeeee
I tested using this software version, but the result was that USB formatting failed and cannot be used
4,272 次查看
ZhangJennie
What's your IDE and version?
Which verion of lpcopen works under your IDE?
4,268 次查看
lilipeeeee
I tested using the program under this file  lpcopen3_02-----  "Periph-sdmmc" .  still can only recognize 32GB SDHC cards!
4,270 次查看
lilipeeeee
I use  KeilV5.34 , verion : lpcopen3_02
4,220 次查看
ZhangJennie
HI lilipeeeee
Have a nice day,
Jun Zhang
4,217 次查看
lilipeeeee
Thanks!
